so far we've been working with LMP92066 device version A0 (marking 79AXN7U) which works just fine with excellent accuracy. Now we got a new batch of boards where the device version as read back in register 1F is A1 (device marking 7BAX89U). There, we see an accuracy of the output voltage of just +/-50..80mV, i.e. the output voltage is 50..80mV lower or higher than the set value (in override mode. register readback verifies that the correct values are written in). So
-is there any change in programming for revision A1?
-does revision A1 even exist or is it a fake chip?
-have you seen similar behavior on revision A1?
Thanks a lot and kind regards,
Jan
