Other Parts Discussed in Thread: PCA9306
Dear all,
I am using an ADS1115 to read 4 analog sensors with a Raspberry pi. I am using the Adafruit ADS1115 library for python to read the data. After 10 minutes, the analogue readings get messed up and unstable unless I disconnect completely the I2C bus. I have checked the code and I am sure the readings are NOT in differential mode and it is a single shot reading mode. Even if I add some time delay it still does not work.
Hardware wise we have checked and the signals are stable even when the ADS is returning messed up values. All the channels are referenced to ground and we have added a high frequency filter to avoid signal noise.
Does anyone has an idea of what could be the problem?
I would much appreciate help! Thanks very much in advance
Many thanks
Alessandra
