Other Parts Discussed in Thread: DLP9500,
I'm using 2 X DLPC410 & DLP9500 in my board with FPGA Design (duplicated for both DLPCs).
I'm able to work with DCLKIN of 250/350MHz but when I'm trying to work with DCLKIN of 400MHz only one of the DLPC-DMDs are working.
From what I've seen when I worked with DCLKIN of 400MHz, both DLPCs ended their INIT state (INIT_ACTIVE is low), I'm sending the first frame (row mode) for both DLPCs ending by MCP - the first DLPC returns me RST_ACTIVE as expected but the second DLPC doesn't return RST_ACTIVE.
When I changed DCLKIN to 350MHz everything works (RST_ACTIVE from "problematic" DLPC works as expected).
From your experience, what am I missing or what could be the reason for this problem?
thank you
