HI,
Is there a way to export image files from FW maerged with image file on GUI?
If yes, Could you let me know how to export it ?
BR
Tazawa
Hi Tazawa,
Thank you for reaching out with your question to the E2E Forum.
Sorry I may not completely understand the question.
If you check in the following user guide in section 3.5, there is the option to create images and then save them as an output file. I am not sure if this is what you are looking for.
Alex Chan
Hi, Alex chan
Thank you for your reply.
My question is that How to export a image file which we merge after Flash.
It means we would like to get a image file after Flash.
We understand it can be update firmware.
after that we need a flashed image file.
If you do not have any solution, Please let me know.
Best Regards
Tazawa
Tazawa-san,
Our team will look into your query and get back to you with an update by tomorrow.
Mayank
Hi Tazawa,
I am not sure what merges or changes you have made in the GUI but have you seen if when you press this update button and then save the firmware does that work and is that what you are looking for?
Outside of that I do not believe we have any feature to read and save the image.
Normally we support uploading firmware and see if the latest firmware has the features you may be looking for?
https://www.ti.com/tool/DLPR350
Alex Chan
