I see the diameter of the mounting holes in the technical data, but cannot find what screw would actually work with this size. What are the sizes of the mounting holes?
Thank you,
Grace
Thank you,
Grace
Hello Grace,
The hole diameter is 3.56 mm. A #6 screw or an M3.5 screw might fit, but it would be very tight. A #5 screw would be ideal, but they are not very common. Instead a #4 pan head screw or an M3 pan head screw should work just fine. If you use a socket head screw, then you should use a washer.
Fizix
