TPS65987D: Is IS25LQ512B-JNLE applicable with TPS65987D?
Guru 29720 points
Part Number: TPS65987D
Hi Team,
My customer considers using IS25LQ512B-JNLE for SPI Flash with TPS65987D.
Is it applicable with TPS65987D?
The application is non-Thunderbolt application.
I believe it is applicable but would like to confirm just in case.
Yaita
  • Hi Yaita,
    Yes if you can confirm with that Flash that it can support 12MHz speed and have a minimum erasable sector size of 4KB I think you should be able to use it. It looks like it have enough space though of the minimum 64kB.
    Thank you,
    Hari
