Part Number: SN55HVD75-EP
I am using a SN55HVD75-EP in my design, and I have a question about the Driver / receiver enable times.
Section 6.6 of the datasheet lists the driver enable time under two different test conditions, with the receiver enabled and with the receiver disabled. Similarly, the datasheet lists the receiver enable time under two different test conditions, with the driver enabled and with the driver disabled.
In my design I will by tying the driver enable pin and the receiver enable pin to the same net, so when the device is switching from driver enabled to driver disabled it will simultaneously be switching from receiver disabled to receiver enabled.
My question is: which driver / receiver enable time applies in this situation?
