Part Number: TUSB8020B
With respect to the question from below thread:
With PWRCTLx/BATENx active high and charging not supported,
1. When over-current event happen and OVERCURxZ is pulled low, the BATENx will be disabled. Correct?
2. When above event happen, the hub will set the overcurrent status in its internal USB hub status register. May i know which register is this referring to? And can it be accessed by OTP?
3. Does the BATENx auto recovers (assert high) after OVERCURxZ is no longer pulled low when the USB load is removed?
