Part Number: TUSB2046B
Other Parts Discussed in Thread: EVM430-FR6047, TPS2042
We are using the USB HUB controller"TUSB2046BIRHBR" in our design,i am getting below observations.
1.USB Enumeration is not happening every power on time properly.
2.some of the boards USB enumeration is happening initial power on only,but later USB HUB down stream ports are getting detected and driver also not loaded on linux prompt.
3.Some of the boards i am getting the crystal output during power on,later after multiple times power and off then i an not getting crystal output correctly and also usb enumeration not happening every time properly.
4.Here i am attaching our designed schematics for reference.
5.Right now i have shorted all over current(oc) pins,all down stream ports are activated at a time.
6.could you please check and suggest what might be missing and why i am facing this issue,some boards are working and some boards are not working with same circuitry.
Thanks & Regards
K.Manikumar
