Part Number: DP83TG720S-Q1
HI sir
We design a circuit , DP83TG720S-Q1 direct comm as below, but comm still fail. did you have any suggestion?
thanks
HI sir
thanks
Hi Alex,
I need a clarification on how do you connect 720 PHYs to the RJ45 wire because 720 PHYs does not support RJ45 cable. Did you used a media converter?
Hillman Lin
Hi Hillman,
We connect DP83848CVV to 720 PHY on our PCBA, so one side is "RJ45" from DP83848CVV usage, the other side is automotive 1000BASE-T1 (TRD_M/P) from 720PHY.
We set one PCBA as a master, the other is a slave, then connect Master's TRD_M/P to Slave's TRD_M/P. If this connection is acceptable, we use 2 PC like above fig., set the IP properly, it should be possible to ping each others.
Thank you.
Hi Chen,
Hillman Lin
