Part Number: DP83867IS
Hello TI Forum!
What should be the register configuration for SGMII loopback checking?
My intention is to measure the SGMII signal voltage and other electrical characteristics of the SGMII signal from DP83867IS PHY.
Here is the register configuration I am planning to implement :
Reference: snla246a.pdf
Below is the test setup I am planning to execute with the evaluation boards I have:
RGMII evaluation board will be configured using an external MDC/MDIO host to generate the PRBS signals through the MDI interface and the SGMII signal will be looped back externally on the other end of the SGMII evaluation board.
SGMII signal electrical parameters will be measured from the SGMII evaluation board.
Could you please verify the register configuration?
Thank you!
