Part Number: TUSB4041I
We are currently trying to perform a high speed signal test on the USB host for our product, which is currently passing throughTUSB4041IPAPR. We realized that a USB 2.0 Test fixture recommended by USB.org and our CPU vendor (https://www.allion.com/test-fixture/hsehet/) is not suitable for generating the test packet directly.
I suspect that the hub does not support EHCI and thus we could not follow the regular procedure from USB.org. After some discussion with the support team from NXP, we were informed that we might need your help to trigger the test packet via Linux rather than using an external test fixture.
NXP provided an example from Microchip hub, and suggested to approach you for guidance on similar approach.
Do you have any guide to set up the USB 2.0 pre-compliance test?
