Part Number: DP83822IF
HI ,
How is the master or slave mode decided in RMII for DP83822 .
ie How we decide whether the PHY should work as RMII master or RMII Slave . what is the criteria?
Eby
Hi Eby,
The RMII master or slave configuration is decided based on availability of clocks.
In RMII Master operation, the device operates off of either a 25-MHz oscillator connected to XI pin or a 25-MHz crystal connected across XI and XO pins. In RMII Slave operation, the device operates off of a 50-MHz oscillator connected to the XI pin and shares the same clock as the MAC. Figures 8-5 and 8-6 in the datasheet show the difference in implementation.
David
You are welcome. Do you have any additional questions? If not, I will close this thread.
David
