Hi,TI
We are using coax mode, if want to use CMLOUTP/N to test the eye diagram, how should the hardware be connected?
The following figure is a test continuation in STP mode, but the COAX mode does not know how to connect.
Hi,TI
Hello zhijian,
we recommend differential configuration for probing. But if you to measure single-ended, then you would need to terminate the negative port with a 50Ω resistor similar to the FPD Link ports.
