Part Number: TCA9554
May I confirm TMUX1574PWR TSSOP 16P 4-CHANNEL MUX Pd(mW) value is ?
Hey Louis,
Please see our FAQ : to Calculate the Max Junction Temperature of an Analog Switch/Multiplexer where we have a calculator that will provide the power dissipation for you. The link for the calculator is at the bottom of the FAQ. I put the numbers in with the max values to find pd(max) and got 16.2mW. Keep in mind this is the max and I wouldn't expect your real life situation to get this high typically. If you wanted to see a closer approximation of what to expect you can input the known values of your use case.
Rami
