Part Number: DP83TD510E
Other Parts Discussed in Thread: DP83848-EP
This question is the follow up of my previous post ( DP83TD510E: DP83TD510E RGMII Media converter Problem - Interface forum - Interface - TI E2E support forums )
We have developed a media-converter using DP83TD510E and as mentioned in my older Post we could not get the communication working between the Ethernet-PHY and T1L-PHY. Our main suspicion is that the RGMII somehow doesn’t work, and we don’t think it is related to Delay or trace-length.
I have attached the simplified schematic of our Board and TX/RX Oscilloscope Captures. To avoid confusion The RX/TX pictures are named according to the Resistors, where the Oscilloscope Probes were placed during the capture.
I have also attached the Errata sheet of the Ethernet PHY (KSZ9031RNX) , I am not sure if the issue described in section “Two RX_CLK clock phases in RGMII 10Mbps mode“ does play a role in our Problem or not, I just thought it worth mentioning it.
