Part Number: SN65DSI86-Q1
Other Parts Discussed in Thread: SN65DSI86, SN65DSI86EVM
we are trying to bringUp the same bridge (via imx8MP hummingbird EVB by solidrun)
we have attached a DELL P2720D DP display to the bridge's EVB using the standard onboard port.
and have been receiving the same error:
Jan 19 13:26:56 imx8mpsolidrun kernel: [drm:ti_sn_bridge_probe [ti_sn65dsi86]] *ERROR* could not find any panel node
note that i2c communications are working fine and we also tried disabling the ASSR and enabling the color bar (
nothing was visible on the display)
please find the attached DTS and boot log.
any help will be appreciated,
Thanks.
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright 2019 NXP
/dts-v1/;
#include <dt-bindings/clock/qcom,rpmh.h>
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/interrupt-controller/irq.h>
#include <dt-bindings/usb/pd.h>
#include "imx8mp-sr-som.dtsi"
model = "SolidRun i.MX8MP HummingBoard Pulse";
compatible = "fsl,imx8mp-sr-som", "fsl,imx8mp";
leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_led>;
/*status {
label = "status";
gpios = <&gpio4 22 0>;
default-state = "on";
power-m2-mpcie {
compatible = "reg-userspace-consumer";
regulator-name = "m2-mpcie-pwr-consumer";
regulator-boot-on;
regulator-supplies = "vcc";
vcc-supply = <®_m2_mpcie_pwr>;
comment = "m.2 and mpcie 3.3V connector switch";
power-usb-port1 {
regulator-name = "usb-port1-pwr-consumer";
regulator-boot-on;
vcc-supply = <®_usb1_host_vbus>;
comment = "USB Port1 vbus power switch";
power-usb-port2 {
regulator-name = "usb-port2-pwr-consumer";
regulator-boot-on;
vcc-supply = <®_usb1_vbus>;
comment = "USB Port2 vbus power switch";
reg_m2_mpcie_pwr: regulator-m2-mpcie-pwr {
compatible = "regulator-fixed";
regulator-name = "m2-mpcie-pwr";
pinctrl-0 = <&pinctrl_m2_pwr>;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio = <&gpio1 10 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_usb1_host_vbus: regulator-usb1-host-vbus {
regulator-name = "usb1_host_vbus";
pinctrl-0 = <&pinctrl_usb1_host_vbus>;
gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_usb1_vbus: regulator-usb1-vbus {
regulator-name = "usb1_vbus";
pinctrl-0 = <&pinctrl_usb1_vbus>;
gpio = <&gpio1 15 GPIO_ACTIVE_HIGH>;
enable-active-high;
reg_usdhc2_vmmc: regulator-usdhc2 {
pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>;
regulator-name = "VSD_3V3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio2 19 GPIO_ACTIVE_LOW>;
regulator-always-on;
reg_vdd_1v8: regulator-vdd-1v8 {
regulator-name = "VDD_1V8";
vdd-3v3-supply = <&buck4>;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
rfkill_m2_wdis {
compatible = "rfkill-gpio";
pinctrl-0 = <&pinctrl_m2_rfkill>;
rfkill-name = "m2_wdis";
rfkill-type = <5>;
reset-gpio = <&gpio1 6 GPIO_ACTIVE_HIGH>;
shutdown-gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>;
status = "okay";
rfkill_m2_gps {
pinctrl-0 = <&pinctrl_m2_gps_rfkill>;
rfkill-name = "m2_gps";
rfkill-type = <6>;
shutdown-gpio = <&gpio1 7 GPIO_ACTIVE_HIGH>;
status = "okay";
rfkill_mpcie_wdis {
pinctrl-0 = <&pinctrl_mpcie_rfkill>;
rfkill-name = "mpcie_wdis";
rfkill-type = <5>;
reset-gpio = <&gpio1 1 GPIO_ACTIVE_HIGH>;
shutdown-gpio = <&gpio1 5 GPIO_ACTIVE_HIGH>;
status = "okay";
sound-hdmi {
compatible = "fsl,imx-audio-cdnhdmi";
model = "audio-hdmi";
audio-cpu = <&aud2htx>;
hdmi-out;
constraint-rate = <44100>,
<88200>,
<176400>,
<32000>,
<48000>,
<96000>,
<192000>;
status = "disabled";
sound-wm8904 {
compatible = "simple-audio-card";
simple-audio-card,name = "wm8904-audio";
simple-audio-card,format = "i2s";
simple-audio-card,frame-master = <&sound_wm8904_cpu>;
simple-audio-card,bitclock-master = <&sound_wm8904_cpu>;
simple-audio-card,widgets =
"Headphone", "Headphone Jack",
"Microphone", "Headset Microphone";
simple-audio-card,routing =
"Headphone Jack", "HPOUTL",
"Headphone Jack", "HPOUTR",
"Headset Microphone", "MICBIAS",
"IN2R", "Headset Microphone";
sound_wm8904_cpu: simple-audio-card,cpu {
sound-dai = <&sai3>;
dai-tdm-slot-num = <2>;
dai-tdm-slot-width = <32>;
sound_wm8904_codec: simple-audio-card,codec {
sound-dai = <&wm8904>;
sn65dsi86_refclk: sn65dsi86-refclk {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <27000000>;
backlight: backlight {
compatible = "pwm-backlight";
// pwms = <&dsi_2_edp_bridge 1000000>;
// enable-gpios = <&tlmm 11 GPIO_ACTIVE_HIGH>;
dsi_2_edp_en: dsi-2-edp-en {
pinmux {
pins = "gpio102";
function = "gpio";
pinconf {
pins = "gpio102";
drive-strength = <2>;
bias-disable;
dsi_2_edp_irq: dsi-2-edp-irq {
pinmux {
pins = "gpio10";
function = "gpio";
pinconf {
pins = "gpio10";
bias-pull-down;
/*panel: panel {
compatible = "simple-panel", "qcom,sc7180-dp";
//backlight = <&backlight>;
panel-width-mm = <2560>;
panel-height-mm = <1440>;
status = "okay";
no-hpd;
port {
panel_in_edp: endpoint {
remote-endpoint = <&sn65dsi86_out>;
&aud2htx {
status = "okay";
&basler_1 {
status = "okay";
&easrc {
fsl,asrc-rate = <48000>;
status = "okay";
&ecspi2 {
#address-cells = <1>;
#size-cells = <0>;
fsl,spi-num-chipselects = <1>;
pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>;
cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>;
status = "okay";
spidev1: spi@0 {
reg = <0>;
compatible = "linux,spidev";
spi-max-frequency = <10000000>;
/*eth0*/
&eqos {
status = "okay";
&flexspi {
pinctrl-0 = <&pinctrl_flexspi0>;
status = "okay";
&i2c2 {
clock-frequency = <100000>;
pinctrl-0 = <&pinctrl_i2c2>;
status = "okay";
/*sound codec*/
wm8904: codec@1a {
#sound-dai-cells = <0>;
compatible = "cirrus,wm8904", "wlf,wm8904";
reg = <0x1a>;
DBVDD-supply = <&buck4>;
MICVDD-supply = <&buck4>;
DCVDD-supply = <®_vdd_1v8>;
AVDD-supply = <®_vdd_1v8>;
CPVDD-supply = <®_vdd_1v8>;
clocks = <&clk IMX8MP_CLK_SAI3>;
clock-names = "mclk";
status = "okay";
&i2c3 {
#size-cells = <0>;
pinctrl-0 = <&pinctrl_i2c3>;
status = "okay";
basler_0: basler_camera_vvcam@36 {
compatible = "basler,basler-camera-vvcam", "basler-camera-vvcam";
reg = <0x36>;
csi_id = <0x00>;
status = "okay";
port {
basler_ep_0: endpoint {
data-lanes = <1 2 3 4>;
clock-lanes = <0>;
link-frequencies = /bits/ 64 <750000000>;
max-lane-frequency = /bits/ 64 <750000000>;
max-pixel-frequency = /bits/ 64 <266000000>;
max-data-rate = /bits/ 64 <0>;
remote-endpoint = <&mipi_csi0_ep>;
adv_bridge: adv7535@3d {
compatible = "adi,adv7533";
reg = <0x3d>;
pinctrl-0 = <&pinctrl_mipi_dsi_en>;
adi,addr-cec = <0x3c>;
adi,addr-edid = <0x3b>;
adi,dsi-lanes = <4>;
gpio = <&gpio1 8 GPIO_ACTIVE_HIGH>;
/*port {
adv7535_from_dsim: endpoint {
remote-endpoint = <&dsim_to_adv7535>;
eeprom_carrier: eeprom@57 {
compatible = "st,24c02", "atmel,24c02";
reg = <0x57>;
pagesize = <8>;
rtc: rtc@69 {
compatible = "abracon,ab1805";
reg = <0x69>;
abracon,tc-diode = "schottky";
abracon,tc-resistor = <3>;
dsi_2_edp_bridge: sn65dsi86@2d {
compatible = "ti,sn65dsi86";
reg = <0x2d>;
ti,dsi-lanes = <4>;
max,dsi-channel = <1>;
ti,dp-lanes = <4>;
// pinctrl-0 = <&dsi_2_edp_en>, <&dsi_2_edp_irq>;
// gpio-controller;
#gpio-cells = <2>;
//interrupt-parent = <&tlmm>;
// interrupts = <10 IRQ_TYPE_LEVEL_HIGH>;
//enable-gpios = <&tlmm 102 GPIO_ACTIVE_HIGH>;
/*vpll-supply = <&src_pp1800_s4a>;
vccio-supply = <&src_pp1800_s4a>;
vcca-supply = <&src_pp1200_l2a>;
vcc-supply = <&src_pp1200_l2a>;
//clocks = <&rpmhcc RPMH_LN_BB_CLK2>;
clocks = <&sn65dsi86_refclk>;
clock-names = "refclk";
no-hpd;
panel@0 {
compatible = ""panel-simple"; // edp
reg = <0>;
// reset-gpio = <&gpio1 8 GPIO_ACTIVE_HIGH>;
enable-gpio = <&gpio1 8 GPIO_ACTIVE_HIGH>;
panel-width-mm = <256>;
panel-height-mm = <144>;
// backlight = <&backlight>;
port {
ports {
port@1 {
reg = <1>;
sn65dsi86_in: endpoint {
remote-endpoint = <&dsi0_out>;
port@2 {
reg = <2>;
sn65dsi86_out: endpoint {
remote-endpoint = <&panel_in_edp>;
&irqsteer_hdmi {
status = "okay";
&hdmi {
status = "okay";
&hdmi_blk_ctrl {
status = "okay";
&hdmi_pavi {
status = "okay";
&hdmiphy {
status = "okay";
&isp_0 {
status = "okay";
&isp_1 {
status = "okay";
/*micro HDMI*/
&lcdif1 {
status = "okay";
&lcdif2 {
/*HDMI*/
&lcdif3 {
&micfil {
pinctrl-0 = <&pinctrl_pdm>;
assigned-clocks = <&clk IMX8MP_CLK_PDM>;
assigned-clock-parents = <&clk IMX8MP_AUDIO_PLL1_OUT>;
assigned-clock-rates = <196608000>;
&mipi_csi_0 {
#size-cells = <0>;
clock-frequency = <266000000>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_266M>;
assigned-clock-rates = <266000000>;
status = "okay";
port@0 {
reg = <0>;
mipi_csi0_ep: endpoint {
remote-endpoint = <&basler_ep_0>;
data-lanes = <4>;
csis-hs-settle = <16>;
&mipi_csi_1 {
status = "okay";
&mipi_dsi {
status = "okay";
//compatible = "fsl,imx8mp-mipi-dsim";
port@1 {
dsi0_out: endpoint {
remote-endpoint = <&sn65dsi86_in>;
attach-bridge;
/*port@1 {
dsim_to_adv7535: endpoint {
remote-endpoint = <&adv7535_from_dsim>;
attach-bridge;
&pcie{
pinctrl-0 = <&pinctrl_pcie>;
reset-gpio = <&gpio4 28 GPIO_ACTIVE_LOW>;
ext_osc = <0>;
clocks = <&clk IMX8MP_CLK_HSIO_ROOT>,
<&clk IMX8MP_CLK_PCIE_AUX>,
<&clk IMX8MP_CLK_HSIO_AXI>,
<&clk IMX8MP_CLK_PCIE_ROOT>;
clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus";
assigned-clocks = <&clk IMX8MP_CLK_HSIO_AXI>,
<&clk IMX8MP_CLK_PCIE_AUX>;
assigned-clock-rates = <500000000>, <10000000>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL2_500M>,
<&clk IMX8MP_SYS_PLL2_50M>;
status = "okay";
&pcie_phy{
ext_osc = <0>;
status = "okay";
&pwm4 {
pinctrl-0 = <&pinctrl_pwm4>;
status = "okay";
&sai3 {
pinctrl-0 = <&pinctrl_sai3>;
assigned-clocks = <&clk IMX8MP_CLK_SAI3>;
assigned-clock-rates = <12288000>;
clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI3_IPG>, <&clk IMX8MP_CLK_DUMMY>,
<&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI3_MCLK1>, <&clk IMX8MP_CLK_DUMMY>,
<&clk IMX8MP_CLK_DUMMY>;
clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3";
fsl,sai-mclk-direction-output;
status = "okay";
&sdma2 {
status = "okay";
&uart3 {
pinctrl-0 = <&pinctrl_uart3>;
assigned-clocks = <&clk IMX8MP_CLK_UART3>;
assigned-clock-parents = <&clk IMX8MP_SYS_PLL1_80M>;
fsl,uart-has-rtscts;
status = "okay";
&usb3_phy0 {
fsl,phy-tx-preemp-amp-tune = <2>;
status = "okay";
&usb3_0 {
status = "okay";
&usb_dwc3_0 {
dr_mode = "host";
status = "okay";
&usb3_phy1 {
status = "okay";
&usb3_1 {
status = "okay";
&usb_dwc3_1 {
dr_mode = "host";
snps,parkmode-disable-ss-quirk;
status = "okay";
&usdhc2 {
assigned-clocks = <&clk IMX8MP_CLK_USDHC2>;
assigned-clock-rates = <400000000>;
pinctrl-names = "default", "state_100mhz", "state_200mhz";
pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>;
pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>;
pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>;
cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>;
vmmc-supply = <®_usdhc2_vmmc>;
voltage-ranges = <1800 1800 3300 3300>;
bus-width = <4>;
status = "okay";
&iomuxc {
pinctrl-0 = <&pinctrl_hog>;
/*pinctrl_edp_mux: kzmuxedpgrp {
fsl,pins = <
MX8MQ_IOMUXC_UART4_RXD_GPIO5_IO28 0x01
pinctrl_ecspi2: ecspi2grp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SCLK__ECSPI2_SCLK 0x82
MX8MP_IOMUXC_ECSPI2_MOSI__ECSPI2_MOSI 0x82
MX8MP_IOMUXC_ECSPI2_MISO__ECSPI2_MISO 0x82
pinctrl_ecspi2_cs: ecspi2cs {
fsl,pins = <
MX8MP_IOMUXC_ECSPI2_SS0__GPIO5_IO13 0x40000
pinctrl_gpio_led: gpioledgrp {
fsl,pins = <
MX8MP_IOMUXC_SAI2_RXC__GPIO4_IO22 0x19
MX8MP_IOMUXC_SAI2_RXFS__GPIO4_IO21 0x19
MX8MP_IOMUXC_SAI2_RXD0__GPIO4_IO23 0x19
MX8MP_IOMUXC_SAI2_TXFS__GPIO4_IO24 0x19
MX8MP_IOMUXC_UART4_RXD__GPIO5_IO28 0x19
pinctrl_hog: hoggrp {
fsl,pins = <
MX8MP_IOMUXC_HDMI_DDC_SCL__HDMIMIX_HDMI_SCL 0x400001c3
MX8MP_IOMUXC_HDMI_DDC_SDA__HDMIMIX_HDMI_SDA 0x400001c3
MX8MP_IOMUXC_HDMI_HPD__HDMIMIX_HDMI_HPD 0x40000019
MX8MP_IOMUXC_HDMI_CEC__HDMIMIX_HDMI_CEC 0x40000019
pinctrl_i2c2: i2c2grp {
fsl,pins = <
MX8MP_IOMUXC_I2C2_SCL__I2C2_SCL 0x400001c3
MX8MP_IOMUXC_I2C2_SDA__I2C2_SDA 0x400001c3
pinctrl_i2c3: i2c3grp {
fsl,pins = <
MX8MP_IOMUXC_I2C3_SCL__I2C3_SCL 0x400001c3
MX8MP_IOMUXC_I2C3_SDA__I2C3_SDA 0x400001c3
pinctrl_flexspi0: flexspi0grp {
fsl,pins = <
MX8MP_IOMUXC_NAND_ALE__FLEXSPI_A_SCLK 0x1c2
MX8MP_IOMUXC_NAND_CE0_B__FLEXSPI_A_SS0_B 0x82
MX8MP_IOMUXC_NAND_DATA00__FLEXSPI_A_DATA00 0x82
MX8MP_IOMUXC_NAND_DATA01__FLEXSPI_A_DATA01 0x82
MX8MP_IOMUXC_NAND_DATA03__FLEXSPI_A_DATA03 0x82
pinctrl_m2_rfkill: m2_rfkill_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO06__GPIO1_IO06 0x19
MX8MP_IOMUXC_GPIO1_IO13__GPIO1_IO13 0x19
pinctrl_m2_gps_rfkill: m2_gps_rfkill_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO07__GPIO1_IO07 0x19
pinctrl_m2_pwr: mp2_pwr_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO10__GPIO1_IO10 0x19
pinctrl_mpcie_rfkill: mpcie_rfkill_grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO01__GPIO1_IO01 0x19
MX8MP_IOMUXC_GPIO1_IO05__GPIO1_IO05 0x19
pinctrl_mipi_dsi_en: mipi_dsi_en {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO08__GPIO1_IO08 0x16
pinctrl_pcie: pciegrp {
fsl,pins = <
MX8MP_IOMUXC_SAI3_RXFS__GPIO4_IO28 0x41/*pcie reset*/
pinctrl_pdm: pdmgrp {
fsl,pins = <
MX8MP_IOMUXC_SAI5_RXC__AUDIOMIX_PDM_CLK 0xd6
MX8MP_IOMUXC_SAI5_RXD0__AUDIOMIX_PDM_BIT_STREAM00 0xd6
MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_PDM_BIT_STREAM01 0xd6
MX8MP_IOMUXC_SAI5_RXD2__AUDIOMIX_PDM_BIT_STREAM02 0xd6
MX8MP_IOMUXC_SAI5_RXD3__AUDIOMIX_PDM_BIT_STREAM03 0xd6
pinctrl_pwm4: pwm4grp {
fsl,pins = <
MX8MP_IOMUXC_SAI5_RXFS__PWM4_OUT 0x116
pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp {
fsl,pins = <
MX8MP_IOMUXC_SD2_RESET_B__GPIO2_IO19 0x40
pinctrl_sai3: sai3grp {
fsl,pins = <
MX8MP_IOMUXC_SAI3_MCLK__AUDIOMIX_SAI3_MCLK 0xd6
MX8MP_IOMUXC_SAI3_TXFS__AUDIOMIX_SAI3_TX_SYNC 0xd6
MX8MP_IOMUXC_SAI3_TXC__AUDIOMIX_SAI3_TX_BCLK 0xd6
MX8MP_IOMUXC_SAI3_TXD__AUDIOMIX_SAI3_TX_DATA00 0xd6
MX8MP_IOMUXC_SAI3_RXD__AUDIOMIX_SAI3_RX_DATA00 0xd6
pinctrl_uart3: uart3grp {
fsl,pins = <
MX8MP_IOMUXC_ECSPI1_SCLK__UART3_DCE_RX 0x140
MX8MP_IOMUXC_ECSPI1_MOSI__UART3_DCE_TX 0x140
MX8MP_IOMUXC_ECSPI1_SS0__UART3_DCE_RTS 0x140
MX8MP_IOMUXC_ECSPI1_MISO__UART3_DCE_CTS 0x140
pinctrl_usb1_host_vbus: usb1hostgrp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO14__GPIO1_IO14 0x19
pinctrl_usb1_vbus: usb1grp {
fsl,pins = <
MX8MP_IOMUXC_GPIO1_IO15__GPIO1_IO15 0x19
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x190
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d0
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d0
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d0
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d0
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d0
MX8MP_IOMUXC_GPIO1_IO04__USDHC2_VSELECT 0xc1
pinctrl_usdhc2_100mhz: usdhc2grp-100mhz {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x194
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d4
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d4
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d4
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d4
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d4
pinctrl_usdhc2_200mhz: usdhc2grp-200mhz {
fsl,pins = <
MX8MP_IOMUXC_SD2_CLK__USDHC2_CLK 0x196
MX8MP_IOMUXC_SD2_CMD__USDHC2_CMD 0x1d6
MX8MP_IOMUXC_SD2_DATA0__USDHC2_DATA0 0x1d6
MX8MP_IOMUXC_SD2_DATA1__USDHC2_DATA1 0x1d6
MX8MP_IOMUXC_SD2_DATA2__USDHC2_DATA2 0x1d6
MX8MP_IOMUXC_SD2_DATA3__USDHC2_DATA3 0x1d6
pinctrl_usdhc2_gpio: usdhc2grp-gpio {
fsl,pins = <
MX8MP_IOMUXC_SD2_CD_B__GPIO2_IO12 0x1c4
