SN65LVDM176: SN65LVDM176
Part Number: SN65LVDM176
Greetings,
  • There was the initiative from the IBIS specialist group to fix the issue in a timely manner with PN SN65LVDM176. We at Lockheed Martin Space design group have reached a critical point where the need of fixing this IBIS model is critical since we are now entering post layout stage
  • Refer to case "CS1456431: IBIS model for SN65LVDM176 shows delay and glitches". Here it shows all the details of the issues
  • Below is the TI specialist latest response committing in fixing this issue
2023-01-13 20:28:30 CST - Marvin Cantos Customer Response
Hi Fernando,
I apologize for the inconvenience this may have caused you. Thank you also for bringing this issue up with us. Our dedicated team will now have the opportunity to fix the issue internally and update the IBIS model for SN65LVDM176.
Please allow me to temporarily put this case on "Resolved" status to close this ticket on your end. Rest assured that our product application specialist will update you through your posted inquiry in our E2E channel.
Thank you for understanding and your patience.
Kind regards,
Marvin O. Cantos
Texas Instruments Customer Support
  • Hello Fernando,
    Thank you for your post and we again apologize for any inconvenience this brings. This model is currently in our design queue, however, since this queue also includes new releases as well as other remodels, we cannot say at the moment when a remodel will be completed.
    To avoid further delays, would an M-LVDS device work in your current application? The SN65LVDM176 is a half-duplex, single-channel LVDM transceiver. With M-LVDS, you get similar power consumption as LVDS, has higher current driver with decrease data rate. The SN65MLVD201 is pin-to-pin with the LVDM176 and has an IBIS model.
    Again, we apologize for the inconvenience this causes.
    Josh
