Part Number: DP83867IR
Hi
From the datasheet SNLS484G section 8.5.4 "PHY Address Configuration" the Figure 8-15 IRPAP PHY Address Strapping Example specifies a pulldown resistor of 2.49k on RX_D4 will result in mode 4.
However, Table 8-3. 4-Level Strap Resistor Ratios specifies the 2.49k resistor to be a pull-up, not a pulldown resistor.
Is it the table or the figure that is correct? If the table is correct, I would suspect a pulldown resistor of 2.49k and no pullup resistor to result in mode 1, not 4.
Please advise.
Regards Lars
