Hi team,
I found VIH A-port has different specification when VCCA is <1.95V and >2.3V.
Could you let me know the VIH when VCCA is between 1.95 and 2.3V?
Itoh
Hi team,
Itoh
But this device is used for open-drain signals; the high level is never actively driven but determined by the pull-up resistors, so it is directly at VCCI, and the minimum VIH should not really matter.
Hi Itoh,
What you are referencing is the recommended operating conditions. Based on the min values provided, it seems to suggest that the value would be Vcci-0.3V.
As Clemen's pointed out, this device is typically used for open drain type protocols so the pull up resistor on the bus (and internal to the device when enabled) will pull the voltage to Vcc anyways. ViH isn't really used for any type of logic for this device on the A/B ports, only for the enable thresholds so knowing Vih isn't very helpful.
-Bobby
