Part Number: DP83826E
Hi ,
The customer uses DP83826E and needs to configure 100 MB full duplex to RMII slave mode.
The phy layer is not working and cannot be pinged. The register value can be seen by reading and writing through the register configuration, but the phy does not seem to be working.
The measured waveforms are normal. When the TX and RX waveforms are powered on, the chip works normally. When the TP-LINK waveforms are connected by network cables, the chip does not work normally.
Attached are the test waveform, schematic diagram and PCB of related parts.
Please help to check and approve.
Thanks~
