Part Number: DS90UB953-Q1
Hi Team,
One of my customers are using DS90UB953-Q1 and having one question. Customers want to figure out how long the valid image signal is coming out from Vout+ since the POC supply is on. So the test the waveform of
POC supply and Vout+ as the following figure. But they cannot figure out the exact point of the valid image signal. From the power on sequence on datasheet it is also not very clear when the valid image is sent from Vout+.
Do we have some criteria/sign when the valid image is sent out form Vout+ so that customers can measure the waveform and determine the time they want to measure?
Any signal turns high/low that indicates the Vout+ signal is valid ?
Regard,
Manu
