Part Number: LMH0366
Other Parts Discussed in Thread: LMH0395,
Hello
I am not sure if I have chosen the right forum. Thanks if someone suggests me a more suitable one.
IC's: LMH0366 and LMH0395
What is the behavior of the ICs at temperatures of a few degrees below -40°C?
- Are all functions of the IC's switched on as soon as the supply voltage is applied?
- Do they consume power? Or is the power consumption reduced by how much?
- Is the function of the ICs limited by which parameters?
- I assume that the ICs will not be destroyed when the supply voltage is applied and that they will not be switched off below -40°C, right?
Thanks Iris
