Part Number: SN74LV541AT
Hi team,
We mentioned in our datasheet that OE is a two-input AND gate with active-low inputs so that, if either output-enable is high, the output is high impedance. But our datasheet didn't show if there is an internal pull down resistor on OE pin. Their bench test was 7if let OE floating, the IC is enabled. Should that be any problem here?
