Part Number: TUSB9261
Other Parts Discussed in Thread: TPD2EUSB30
嗨,TI,
我正在开发带有TUSB2的USB 0.9261 - SATA适配器。
请您检查随附的原理图以评估是否有任何错误?欢迎所有建议。TUSB9261.pdf
嗨,TI,
嗨,
谢谢,我的中文不好。 我等一下会看, 看完之后会马上提供我的反馈。
Nicholaus
Thank you for referring to the EVM when creating your schematic. It is almost the same, except the R38 is grounded instead of floating. It should be fine as long as the crystal datasheet advises pulling this to GND.
Some other potential issues:
The USB lines use RF chokes instead of ESD protection chips - inductors can have a negative effect on signal integrity. Recommend using the TPD2EUSB30 as used in the EVM to ensure the best signal quality. Poor signal quality can cause USB communication issues.
The USB SS Rx lines use 0.1uF capacitors. The recommendation is either to make these DC-coupled with no caps, or to change the cap value to the standard 0.33uF capacitors.
Nicholaus
Let me know if you have any more questions. 若果你有的问题,就告诉我的问题。
谢谢,
Nicholaus
