Part Number: ONET4251PA
Other Parts Discussed in Thread: ONET4201PA
A question was asked about " if the device could be used below 1Gbps. Actual data rate planned to use is from 150Mbps to around 2.5Gbps." The response was that the device would operate at 150Mbps but the specs would not be guaranteed. Can you expand on the minimum data rate operation? I am looking for a limiting amp with a scalable data rate from 1Gbps on the high end to as low as 10Kbps on the low end. Is there a way to clarify what the minimum data rate is and what parameters would be out of spec?
