Part Number: DS320PR1601
Other Parts Discussed in Thread: CDCDB800
1 a)If we use SM bus for programming the redriver(DS320PR1601) instead of EEPROM, where will be the data saved?
b)Don't we need to program every time we turn on the add in card module?
2 Similarly for clock buffer CDCDB800, we can enable the clk out either by enabling the SMB enable bit(OUT_EN_CLK) or via OE# hardware pins.
a)If I intend to use SM Bus register instead of hardware pins, will the register setting retain after power off?
Thanks and Regards,
Shekha Shoukath
