Part Number: DS125DF1610
Currently we are using DS125DF1610 in the communication equipment. We want to check with you about 3 points:
- When doing CDR reset, does it reset the CTLE and DFE parameters? Or only relock the CDR?
- When CDR unlocks due to some issue like signal integrity, is it possible to relock CDR in case that the input signal is always there?
- Is there register to configure the CDR bandwidth?
- Is there a register to configure the loop back path: TX->RX and RX->TX?
For Item 3&4, I couldn't find the register in the programming guide. If you got latest programming guide to support that, can you share with us?
Thanks!
Qiang
