Part Number: XIO2001
Hi, TI experts
I have an inquiry about the differences between XIO2001ZWS and XIO2001ZGU.
The customer is using XIO2001ZWS as XIO2001ZGU has been discontinued.
However, in the field, there was no problem with products to which XIO2001ZGU (old version) was applied, but the following symptoms appeared intermittently in products to which XIO2001ZWS was applied.
- Symptom: The chip is not recognized and must be reset to resume normal operation.
Q1) Is there a solution to why the above symptoms occur?
Q2) I wonder if it is due to the difference between XIO2001ZWS and XIO2001ZGU. Could you please explain if there are any differences?
Please check. Thank you.
