Part Number: DP83867CR
Dear,
One customer used DP83867 for his application and found that the MDIO signal is abnormal.
When RESET=0, the MDIO is normal,
but after finishing RESET(RESET=1), MDIO is pull low.
If serial one 100ohm resistor between MAC and PHY, MAC level is normal but PHY is pulled low.
The schematic is attached.
Finally, by referred this post:https://e2e.ti.com/support/interface-group/interface/f/interface-forum/717497/dp83867is-mdio-signal-of-dp83867is
leave the GPIO float, the MDIO signal changed normal. Why? Why the GPIO affect the MDIO signal? Could you please help to analyze how the GPIO affect the MDIO which caused PHY behavior abnormal?
Best regards
Kailyn
