Part Number: DP83867IS
Other Parts Discussed in Thread: DP83867IR,
For the phy we use we intermittently see link down/up toggling in 1G mode, all we can see after following the troubleshooting guide is that the SME register shows very high values before going bad.
But it's not clear to us what these errors mean and what causes them, any guidance here is appreciated.
Additionally we have noticed that when forcing the phy in master mode the unstable link issue does not manifest itself.
Another question we have is what we noticed in the DP83867IR DS, there footnote 3 for the strapping says "Autoneg Disable should always be set to 0 when using gigabit Ethernet." but we have not strapped the RX_CTRL pin, our question here is if the register setting workaround is sufficient to make gigabit ethernet work properly and acts as autoneg disable to 0 or if we must strap this pin to mode 3 for proper gigabit functionality
