DS90UB954-Q1: Handle the virtual channel
Part Number: DS90UB954-Q1
We have a video source that output A/B frame with different virtual channels.
Is it possible to route or bypass a specified virtual channel in the deserailizer side? Thanks.
    Thank you for reaching out. Are you asking if it is possible to divide the input video stream into two different outputs according to the virtual channel? If so, this is not possible. Forwarding is based on the RX port not the virtual channels. The entire video stream on the RX port will be output by the deserializer.
