Part Number: SN65LVCP114
Based on SN65LVCP114, the schematic design of the module has been completed. Please confirm if the relevant design of SN65LVCP114 is correct, and attach the schematic diagram of the module.
Greetings Tony,
Schematic loos fine.
1). Please note on the input side - CIN0 and CIN1 - we are connected directly to U7B. I am assuming either there is AC coupling Cap integrated within this device. Otherwise please make sure common mode voltage meets LVCP114 requirements.
2). Also, it seems you are using this device as a 1:2 mux. Please note there is another part DS160PR412- data sheet link below. You can use either part:
Regards, Nasser
