Part Number: DP83867IS
Other Parts Discussed in Thread: DP83867IR
Hi Team,
This question about DP83867IS and DP83867IR.
The customer is using it in Three-supply mode(1.1V, 1.8V, 2.5V).
They understand that the correct power on sequence should be to ramp up VDDA2P5(2.5V) then VDDA1P8(1.8V).
However, VDDA1P8(1.8V) ramps up before VDDA2P5(2.5V) due to mistake design on their board.
When VDDA2P5(2.5V) starts to rise after VDDA1P8(1.8V) rising, VDDA2P5(2.5V) will be clamped at 1.5V on the way.
We would like to confirm whether this behavior is normal or not.
That is, does this device have a clamp circuit for protection, and if VDDA1P8(1.8V) rises first, VDDA2P5(2.5V) will be clamped at 1.5V?
Please check the attachment for actual power on sequence.
