UCD3138A: UCD3138ARGCR
Part Number: UCD3138A
Hi
I was giving differential voltage output from the current sensor to the differential pins of EADC pins. I need to calculate total EADC error calculation for the microcontroller. Can you provide a formula to calculate the Total ADC error. and ADC count calculation.
 Part number :UCD3138ARGCR.
And for the single ended ADC pin i Calculated the total error using the following formula. i would like to get the correct formula from your side.
DATASHEET Values
ADC12 INL integral nonlinearity, end point –3.9    ±2    4.5 LSB
ADC12 DNL differential nonlinearity(2)   –0.8/+2.4 LSB(Typical Value)
Formula,
TUE= SQRT (INL^2+DNL^2)
