DS125BR401: DS125BR401SQE schematic and layout review request
Part Number: DS125BR401
Other Parts Discussed in Thread: DS250DF810,
Dear TI Support Team,
could you help review the DS125BR401SQE and DS250DF810 schematic and layout ,the document as attachment.thanksU1&U19.pdfU1U19.zip
  • Hi Cickey,
    I can review the schematic and share feedback by end of this week. I can review the layout and share feedback by end of next week, 6/28.
    Can you share the name of the customer for my information? If you wish to keep customer name private, you can share with me via E2E private message.
    Lucas
  • Hi Cickey,
    Here is my feedback on the schematic. I only reviewed networks directly connected to U1 and U19. Note that the customer is still responsible for ensuring their design will operate as intended.
    U1_DS125BR401_Schem_Review.pdf
    U19_DS250DF810_Schem_Review.pdf
    Some general comments I have:
    • I see there is an EEPROM connected to SDA/SDC of U19, however the retimer is configured for SMBus slave mode. This means the EEPROM will not be used to configure the retimer.
    • I see nets connected to U19 are labeled with "KR". Note that DS250DF810 does not support link training or auto-negotiation protocols.
    Lucas
  • Dear Lucas
    thank for your quick feedback and support;
    the customer is SUMA TECHNOLOGY, TI's KMM,a development enterprise server customer.
  • Dear Lucas,
    I will send this document to customer for checking and loop customer in the e2e post.if any question,maybe trouble you again.
  • Hi Cickey,
    Thank you for sharing the customer name and looping them in. I'll hold off on starting layout review until they check over my feedback, as their comments/questions could impact how I'll review the layout.
    Lucas
  • Dear Lucas,
    customer can' register MY.TI account,so they can't reply the post on E2E,i had transfer customer reply in the post.,please refer to the attachment;
    can you share your email address and we can communicate by mail.
    ANSWER.zip
  • Hi Cickey,
    I'm expected to handle customer support communication through E2E so unfortunately I can't share my email.
    Thank you for sharing customer feedback, I'll work on reviewing the layout.
    Lucas
  • Hi Cickey,
    Can you share the business case of this project?
    Lucas
  • Hi Cickey,
    Here are my comments on the layout. Note that the customer is still responsible for ensuring their design will work as intended.
    U19 DS250DF810:
    • Make sure high-speed traces maintain 100-ohm differential impedance.
    • The best method to make sure differential impedance is maintained with no discontinuities is via high-speed layout simulation or TDR measurement.
    • High-speed trace length matching looks good.
    • We recommend using smooth curves instead of 135 degree straight edges for high-speed traces when transmission speed is >10G.
    • High-speed traces are consistently surrounded by continuous ground planes 1 layer above and below.
    • I recommend including a ground plane on the same layer as high-speed traces as well to surround traces as a reference.
    • High-speed vias should follow the 10/20/40 rule for drill/pad/anti-pad diameter. My rough measurement showed high-speed vias are 8 mil/18 mil/28 mil.
    • We recommend back-drilling high-speed vias to prevent via stubs.
    • Device ground and power planes look good.
    U1 DS125BR401
    Lucas
