TCA9800: PU resistor on B side
Part Number: TCA9800
Other Parts Discussed in Thread: TCA9803, , TCA9802, TCA9509
Hi
My deign is VCCA =1V1 and VCCB=3v3
and the system have some extend device that cause PU on B side.
And I see the VIL in DS is (< 0.3 x VCCB)
I can confirm my system B side VIL is in spec ( < 0.3 X VCCB).
Does this mean my design is ok ?
  • Hi Dimitry,
    Pull-up resistors cannot exist on B-side due to the internal current source of the device. The IEXT-I and IEXT-O must be satisfied at all times for the direction control of the buffer to work - passing LOW logic signals across the buffer in both directions during a point of contention.
    It is recommended to remove these pull-up resistors on the B-side. IF stronger pull-up current is needed, consider moving to the TCA9803 which has stronger current drive to VCC.
    Tyler
  • Hi
    Becuase side B have expansion slot like PCIE slot.
    We are not sure PU status on side B , and it have weak PU resistor like10K.
    Or do you have any other suggestion to replace TCA9800 ?
  • You must not connect the TCA980x's B side to any circuit that might have a pull-up.
    But you could exchange the A and B sides.
  • Hi Dimitry,
    You can do according to what Clemens has suggested by switching A and B sides of the TCA9802.
    Have you looked into the TCA9509? This device seems like it would be a better solution for your design.
    No pull-ups can exist on A-side however. B-side pull-ups are allowed for TCA9509.
    Tyler
