Part Number: DP83848I
Other Parts Discussed in Thread: AM5728
我目前在基于AM5728的开发板上使用了DP83848作为pru mii收发器,在系统启动中能正常识别到收发器。但是网口无法使用,通过ip addr命令看到网口状态一直为NO-CARRIER,state down,使用ifconfig命令分配ip地址后也无法通信,并且不能ping通自己。请协助检查一下pcb设计与设备树配置有无问题,给出解决问题的意见。原理图如下1121.Schematic Prints.pdf
设备树中相关配置
* Copyright (C) 2015-2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
model = "TI AM5728 IDK";
//compatible = "ti,am572x-beagle-x15", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7";
//compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74",
// "ti,dra7";
aliases {
ethernet2 = &pruss2_emac0;
ethernet3 = &pruss2_emac1;
/* Dual-MAC Ethernet application node on PRU-ICSS2 */
pruss2_eth {
compatible = "ti,am57-prueth";
pruss = <&pruss2>;
sram = <&ocmcram1>;
interrupt-parent = <&pruss2_intc>;
pruss2_emac0: ethernet-mii0 {
phy-handle = <&pruss2_eth0_phy>;
phy-mode = "mii";
interrupts = <20>, <22>;
interrupt-names = "rx", "tx";
/* Filled in by bootloader */
local-mac-address = [00 00 00 00 00 00];
pruss2_emac1: ethernet-mii1 {
phy-handle = <&pruss2_eth1_phy>;
phy-mode = "mii";
interrupts = <21>, <23>;
&mac {
status = "okay";
dual_emac;
&cpsw_emac0 {
phy_id = <&davinci_mdio>, <1>;
phy-mode = "rgmii";
dual_emac_res_vlan = <1>;
&cpsw_emac1 {
phy_id = <&davinci_mdio>, <2>;
phy-mode = "rgmii";
dual_emac_res_vlan = <2>;
&gpio3 {
status = "okay";
&gpio5 {
status = "okay";
&pruss1 {
status = "disable";
pru1_0: pru0@4b234000 {
interrupt-parent = <&pruss1_intc>;
interrupts = <16>, <17>;
interrupt-names = "vring", "kick";
status = "okay";
pru1_1: pru1@4b238000 {
interrupts = <18>, <19>;
status = "okay";
&pruss2 {
status = "okay";
pru2_0: pru0@4b2b4000 {
status = "okay";
pru2_1: pru1@4b2b8000 {
status = "okay";
&pruss2_mdio {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&pru2_mii_pins_default>;
pruss2_eth0_phy: ethernet-phy@0 {
reg = <1>;
interrupt-parent = <&gpio3>;
interrupts = <26 IRQ_TYPE_EDGE_FALLING>;
pruss2_eth1_phy: ethernet-phy@1 {
reg = <3>;
interrupt-parent = <&gpio5>;
interrupts = <17 IRQ_TYPE_EDGE_FALLING>;
&pruss2_mdio {
reset-gpios = <&gpio7 10 GPIO_ACTIVE_LOW>,
<&gpio3 25 GPIO_ACTIVE_LOW>;
reset-delay-us = <2>; /* PHY datasheet states 1uS min */
&dra7_pmx_core {
gpio3_pins: gpio3_pins {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x3548, (PIN_OUTPUT_PULLUP | MUX_MODE14)) /* vin1a_d21.gpio3_25 */
DRA7XX_CORE_IOPAD(0x354c, PIN_INPUT_PULLUP | MUX_MODE14) /* vin1a_d22.gpio3_26 */
gpio5_pins: gpio5_pins {
DRA7XX_CORE_IOPAD(0x3644, (PIN_INPUT_PULLUP | MUX_MODE14)) /* RMII_MHZ_50_CLK.gpio5_17 */
gpio7_pins: gpio7_pins {
DRA7XX_CORE_IOPAD(0x37b0, (PIN_OUTPUT_PULLUP | MUX_MODE14)) /* spi1_cs0.gpio7_10 (A24) */
pru2_mii_pins_default: pru2_mii_pins_default {
DRA7XX_CORE_IOPAD(0x36b8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr1.pr2_mii_mt_clk */
DRA7XX_CORE_IOPAD(0x36d4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr8.pr2_mii0_txen */
DRA7XX_CORE_IOPAD(0x36e4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr12.pr2_mii0_txd0 */
DRA7XX_CORE_IOPAD(0x36e0, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr11.pr2_mii0_txd1 */
DRA7XX_CORE_IOPAD(0x36dc, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr10.pr2_mii0_txd2 */
DRA7XX_CORE_IOPAD(0x36d8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr9.pr2_mii0_txd3 */
DRA7XX_CORE_IOPAD(0x36e8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr13.pr2_mii_mr0_clk */
DRA7XX_CORE_IOPAD(0x36ec, (PIN_INPUT_PULLDOWN | SLEWCONTROL | MUX_MODE11)) /* mcasp1_axr14.pr2_mii0_rxdv */
DRA7XX_CORE_IOPAD(0x36b4, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp1_axr0.pr2_mii0_rxer */
DRA7XX_CORE_IOPAD(0x370c, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp2_axr2.pr2_mii0_rxd0 */
DRA7XX_CORE_IOPAD(0x36f8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp2_fsx.pr2_mii0_rxd1 */
DRA7XX_CORE_IOPAD(0x36f4, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp2_aclkx.pr2_mii0_rxd2 */
DRA7XX_CORE_IOPAD(0x36f0, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_axr15.pr2_mii0_rxd3 */
DRA7XX_CORE_IOPAD(0x3724, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp3_aclkx.pr2_mii0_crs */
DRA7XX_CORE_IOPAD(0x3728, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp3_fsx.pr2_mii0_col */
//DRA7XX_CORE_IOPAD(0x3710, (PIN_INPUT_PULLDOWN | SLEWCONTROL | MUX_MODE11)) /* mcasp2_axr3.pr2_mii0_rxlink */
DRA7XX_CORE_IOPAD(0x3774, (PIN_INPUT_PULLUP | MUX_MODE11)) /* gpio6_10.pr2_mii_mt1_clk */
DRA7XX_CORE_IOPAD(0x3778, (PIN_INPUT_PULLUP | MUX_MODE11)) /* gpio6_11.pr2_mii1_txen */
DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat1.pr2_mii1_txd0 */
DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat0.pr2_mii1_txd1 */
DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_cmd.pr2_mii1_txd2 */
DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_clk.pr2_mii1_txd3 */
DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat2 .pr2_mii_mr1_clk */
DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat3.pr2_mii1_rxdv */
DRA7XX_CORE_IOPAD(0x372c, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp3_axr0.pr2_mii1_rxer */
DRA7XX_CORE_IOPAD(0x37a0, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat7.pr2_mii1_rxd0 */
DRA7XX_CORE_IOPAD(0x379c, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat6.pr2_mii1_rxd1 */
DRA7XX_CORE_IOPAD(0x3798, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat5.pr2_mii1_rxd2 */
DRA7XX_CORE_IOPAD(0x3794, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat4.pr2_mii1_rxd3 */
DRA7XX_CORE_IOPAD(0x3698, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* xref_clk1.pr2_mii1_crs */
DRA7XX_CORE_IOPAD(0x3694, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* xref_clk0.pr2_mii1_col */
//DRA7XX_CORE_IOPAD(0x3730, (PIN_INPUT_PULLUP | SLEWCONTROL | MUX_MODE11)) /* mcasp3_axr1.pr2_mii1_rxlink */
DRA7XX_CORE_IOPAD(0x36a4, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_aclkx.pr2_mdio_mdclk */
DRA7XX_CORE_IOPAD(0x36a8, (PIN_INPUT_SLEW | MUX_MODE11)) /* mcasp1_fsx.pr2_mdio_data */
