LMH0376: OUTPUTS
Part Number: LMH0376
Other Parts Discussed in Thread: LMH0356
In my project we are using two LMH0376 IC's, based  upon selection lines input routed to the output.here we have two outputs,
1.Based upon selection lines same output routed to the both the outputs ?
2.If we need only one output, if we taken output from SDO0, what will be the status of another output and vice versa.
  • Hi Babu,
    1). Yes same input input is routed to both outputs.
    2). Both outputs are active. Through the register you can mute the un-wanted output.
    Please note there is also LMH0356 with the same functionality as well. What is the reason for not using LMH0356 device?
    Regards, Nasser
