Part Number: SN65DP141
A account has below questions about SN65DP141, would you like kindly help to support them?
- Can the amplitude of the output signal at the OUTX port of SN65DP141 amplify the amplitude of the input signal, i.e. let VOUT_AMP=Gain*Vin_amp?
- For the same input signal (same Vin_amp), how should the SN65DP141 be configured in order to achieve maximum vout_amp amplitude? If the EQ_DC_GAIN=0DB, EQ_AC_GAIN=15DB, TX_DC_GAIN=6DB, the maximum VOUT_AMP output amplitude can be made (regardless of the output amplitude being limited by the IC), Right?
