Part Number: DP83867IS
Hi.
We tested it using a new board and register.
There are 2 problems.(attachment pdf file)
(1) 1000 Base-T, Point Template Test(w/ Disturbing Signal)
-.Differences in performance by register(1000Base-T mode reg. 0x0140)
--> Successful when inserting register, failed when removing register
(2) 1000 Base-T, Transmitter Distortion(w/ Disturbing Signal)
--> Workaround if only a particular pair fails (ex. D pair is fail)
(3) There is a 125MHz(EMC) noise problem. We need a solution.
please check it
[Share existing questions]
