DP83869HM: DP83869HMRGZR - 1% TX error issue
Part Number: DP83869HM
Hey
Following this post:
https://e2e.ti.com/support/interface-group/interface/f/interface-forum/1459668/dp83869hm-dp83869hmrgzr---schematic-check-and-advise-regards-grounding-issue-with-ethernet
we are now testing the board and we come across a problem
there are up to 1% TX error
but 0% errors on the RX side.
working with SGMII to MDI only 100/10 with magnetics.
we test it with IPERF
i will attach some photos
kindly help with what we can do
1. already replaced the magnetics with another
2. fixed all the previous issues from the previous post
we have tested 4 units
Amit P
  • Hi Amit,
    Could we look at the updated schematic?
    Also, if possible, could you put the PHY into loopback mode and do an external loopback test to see if there are no errors between the MAC and the PHY?
    Please refer to the datasheet section 7.3.4 for more information on the loopback test. External loopback test should flag any packet loss issue from the MAC to the PHY to the RJ45 connector.
    Please let me know.
    J
