Part Number: TMDS1204
For HPD IN signal, for sink application, if i used level translator to convert the HPD_IN signal from 5V to 3.3V using inbuilt level shifter and can use HPD_OUT signal as 3.3V IO level and using one level shifter externally to convert from 3.3V to 5V it will not affect the HPD IN and HPD_OUT signals in redriver IC. Please confirm
If I am operating HDMI IC as 40 Gbps, 10 Gbps per lane, what should be the Frame rate for this IC.
