Part Number: TCAL9539
Hi
Could you please provide the furnace temperature welding file for this product
thank you
Hi Ivy,
Are you referring to reflow soldering?
These two documents might help answer your question.
Tyler
Hi
Good afternoon. However, when we were soldering, we found that the pins were not soldered. Could you please help us confirm what the reason isTCAL9539PWR.docx
Hi Ivy,
This could be multiple different factors. Maybe the reflow profile needs to be hotter peak temperature.
The oxidation could be other materials in the solder paste that is causing the metal of the IC to react in such a way.
Was the TCAL9539 properly placed by the pick and place machine? Looks like the solder welded to the bottom of the pin but did not encapsulate the pin or am I wrong here?
Tyler
Hi Ivy,
I am not too familiar with determining if the pin is oxidized.
Is this only affecting one device, or many devices in the same reel? Is the supposed oxidation random or appearing in the same region?
Tyler
