TUSB2046I: Clarification required on USB Port Power Enable/Disable Behavior
Dear Team,
We are working with the TUSB2046IBVF and TPS2062DGNR. We have observed that USB power to the downstream ports is enabled only when the upstream port is detected. However, the power remains enabled even after the upstream port is disconnected. Our expectation is that the port power should be disabled once the upstream port is removed. Could you please clarify how the port power is controlled or enabled/disabled in this case? Is it possible to disable the downstream port power when the upstream port is disconnected?
Monisha M
