Part Number: LM62460
The design is updated as per your comments.
And, Can you please clarify that the 6th point you mentioned to use Electrolyte ESR Caps, is there any part number and value of the caps. Please recommend.
(Consider adding damping on the input filter stage to avoid unwanted overshoots caused by the ferrite bead and the Input filter capacitors coupling. You can calculate the Damping ESR required to be the characteristic impedance of the LC filter i.e; root(L/Cin_ceramics) in your case. )
And also confirm, the CBOOT, RBOOT with SW connection is proper or not.
And the Attached updated design for your review.
