TUSB8041: Pls help check the schmetic
Part Number: TUSB8041
Dear Sir
Could u hlep review the schmetic ,thanks!USB sch.pdf
  • Hi Gabriel:
    1: for decoupling caps, each power supply need at least 1 cap close to supply pin on PCB.
    2:  FULLPWRMGMTZ pin is high which disabled power switching.
        but pwrctl_x/Baten pins were pulled high, do you want to enable battery charging?
        battery charging will not work if power switching was disabled.
    3: recommend C10054 to 1uf, 4.7uf will make GRST low too long.
    4: need pullup on SCL/SDA.
    Best
    Brian
