ESD2CAN36-Q1: TCAN1057 ESD protection
Part Number: ESD2CAN36-Q1
Other Parts Discussed in Thread: TCAN1051, ESD2CAN36, ESD2CAN24-Q1, , ESD2CAN27-Q1
Dears:
We are currently designing a 24V automotive system and plan to use the 36V CAN ESD protection diode ESD2CAN36DBZRQ1 to protect the CAN transceiver TCAN1057.
Regarding this combination, we have the following questions:
  1. Clamping Voltage and Protection Effectiveness: Since the 36V ESD diode has a relatively high clamping voltage over 60V, can it effectively protect the TCAN1057  +/-58V from transient ESD strikes? Or is it highly recommended to switch to the TCAN1051 instead for better compatibility?
  2. Customer Use Cases: Are there any existing production-proven customer applications or reference designs utilizing this exact combination (ESD2CAN36 + TCAN1057) in 24V systems?
  3. Validation & Testing Data: Has TI conducted any specific correlation testing, system-level ESD testing, or failure analysis for this specific combination? If so, could you share the relevant test reports or application notes?
Thank you for your support, and we look forward to your professional advice.
