Part Number: DP83826AI
DP83826AI_Schematic_20261006.pdf
Hello TI Team,
The attachment is the schematic of DP83826AI. Could you have a check the design?
Hello TI Team,
Please look to leverage our DP83826A schematic checklist file. This is an easy to use document which houses our best learnings. If there is a question that is still outstanding that this file does not address, I can happily assist further.
Sincerely,
Gerome
Hi
Could you check below check list again?
DP83826AI_Schematic_20261007.pdf
5076.DP83826A_Schematic_Design_Review_Checklist_v0.1_JBUS.xlsx
Best Regards!
Wang
Hi Wang,
My comments:
- Which mode does TI generally recommend?
[GC] TI generally recommends enhanced mode.
- Please confirm crystal meets datasheet requirements
- Please ensure Reset is idle high due to active low nature of pin
- This application is for an automotive. Do we can use the transformer-less network application? Following design showed in datasheet: Is the common-coil necessary?
[GC] Transformerless should work. I am unclear about what you mean by common-coil. Do you mean common mode choke (CMC)? If so, this is not required.
Sincerely,
Gerome
