Part Number: FPC402EVM
Other Parts Discussed in Thread: FPC402, FPC401
Hi Drew,
Following up on my earlier thread, and thanks for the answers there. We bought the FPC402EVM and have it running from our BMC: address assignment, broadcast writes, prefetch and stuck-bus recovery all work. Two documents would help us finish the evaluation.
1. The FPC402 Programmer's Guide (SNLU227). The datasheet points to it but it isn't on ti.com. The FPC402-DESIGN link you shared gives me "Access Denied", and TI support (case CS3621986) didn't resolve it. Could you send it, or approve the request on your side?
2. The FPC402EVM schematic. SNLU222 doesn't include it and the EVM page has no design files. We're using the FPC401EVM schematic (SV601279 Rev B) for now. Is the FPC402EVM the same board apart from the device?
I've found two places where the FPC402 seem to differ from the FPC401 guide (SNLU221), which is why we need SNLU227:
- Register 0xF0 reads 0x10 on the FPC402 (SNLU221 gives 0x00), while 0xF1 reads 0xA0, the same as the FPC401. What's the reliable way to tell the two apart in firmware?
- REG_RST (0x00 bit 7) resets a port's SCL timing register to 0x98, but SNLU221 says REG_RST leaves port registers alone. Is that expected on the FPC402?
Mohsen
